Eddies in Laminar ?
Old   December 14, 2002, 14:45
Default Eddies in Laminar ?
bharath
Hello
I would like to knw if an eddy or..any vortices,,,can be created in laminar flows in ducts,channels etc ?? if such interactions are present..is it wise to assume Steady State assumptions for CFD problems...??
Thanks
Bharath
Old   December 16, 2002, 03:56
Default Re: Eddies in Laminar ?
Dean
Laminar flows can contain vortices, and they can be unsteady. It depends on the details of the problem you are interested in.
Old   December 16, 2002, 13:51
bharath
hello consider a case of BAckward Facing Step...in a rectangular duct due to sudden increase in the diameter of the duct ..is it possible that the vortex generated ...is due to a Laminar flow ?
Thanks
Bharath
Old   December 16, 2002, 19:19
Dean
Maybe - check the Reynolds number.
Old   December 17, 2002, 00:05
greg
Vortices are not generated "because" the flow is laminar, but vortices can exist in laminar flows - the classic case is cross-flow over cylinder. At very low Re, the flow is attached. As the Re number increases the flow detaches, forming standing eddies as the shear layers roll up. Beyond a certain value of Re (O(100) as I recall, but it's been a while) the eddies begin to shed. The flow is still laminar, the vortices are created by the vorticity contained in the separating shear layers, and the flow is strongly unsteady.
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 22:22
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 10:15
Laminar & Eddies ?? Bharath FLUENT 8 January 21, 2003 13:13
