February 16, 1999, 11:50 |
Unstructure grid " Advanced Front"
i need any help to build up the AFT Algorith... please.. or any other unstructure grid generation.....
February 17, 1999, 10:10 |
Re: Unstructure grid " Advanced Front"
you can find information at the following web sites: http://www-users.informatik.rwth-aac...eneration.html http://www.andrew.cmu.edu/user/sowen/mesh.html Hope it helps Robert Robert Schneiders MAGMA Giessereitechnologie GmbH D-52072 Aachen Kackertstr. 11 Germany Tel.: +49-241-88901-13 email: rjs@magmasoft.de www: http://www-users.informatik.rwth-aachen.de/~roberts/ |
February 21, 1999, 11:37 |
i didn't find the algo. in these sites... do u know any other sites.. or avaliable papers...in this section
Thanks for all... Eng. M. El-Farran |
March 5, 1999, 20:58 |
Rainald Lohner, Shayar Pirzadeh, and Jaime Peraire are some of the big names to look up in your literature search on the advancing front method. Some of the original papers outlining the algorithm appear in the International Journal for Numerical Methods in Fluids, specifically S.H. Lo (1985) in two dimensions, and Lohner and P.C. Parikh (1988) in three dimensions. Peraire and co-workers did their initial work about the same time as well.
The basic concept is to start with an initial boundary discretization (or "initial front") and proceed to march into the computational domain, updating the front list as new cells are added. When the list of faces/edges on the front is reduced to zero, the mesh is complete. Two advancing front mesh generators which I am aware of are FELISA and VGRIDns. VGRIDns does not come with source code, but in six years of using it I have found it quite powerful, easy to use, and reliable. It can create boundary layer tetrahedra for viscous flows as well. |
unstructure grid genaration method (link of download) | mazdak | Main CFD Forum | 0 | October 21, 2009 02:23 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
instructional cfd code on unstructure grid | Quain Tchew | Main CFD Forum | 2 | January 18, 2002 03:24 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
