mould flow in casting process
Old   December 10, 2002, 04:55
Default mould flow in casting process
seeker01
I would like to use CFD method to simulate the flow of molten metal in the mould of casting process, such as sand casting.
As you know, the mould has inlet(s), called gates, but no outlet. The molten metal will flow to fill up the mold.
I want to analyse the problem in 2D. What CFD technique is suitable for me?
The flow is incompressible and viscous and unsteady.
If you do have source code, can you email me for reference?
Thanks.
Old   December 10, 2002, 19:20
Default Re: mould flow in casting process
CFD Man
There have been extensive research on this area using VOF. Try to search with these key words: CFD+VOF+cast*/mould*
You should be able to get plenty of references.
CFD MAN
Old   December 10, 2002, 22:13
seeker01
what is VOF ?
Old   December 11, 2002, 01:43
CFD Man
Its a free surface modeling technique. Stands for volume of fluid.
CFD MAN
Old   December 18, 2002, 10:37
chidu
The group of Douglas Kothe at Los Alamos National Laboratory is working in this area. You can search in their website. They also use the VOF method.
regards, chidu...
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
gasification process in an entrained flow gasifier abiyik67 FLUENT 0 August 17, 2009 03:32
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
Help: Poiseulle flow benchmariking Mohammad Kermani Main CFD Forum 1 November 12, 1999 17:15
Casting Process Simulation Anil Shenoy Main CFD Forum 1 February 22, 1999 12:56
