Free surface
Old   December 9, 2002, 18:47
Default Free surface
aki
I am wondering how accurately the commercial cfd codes can simulate the free surface flow around a ship. This problem is generally very difficult especially if you want to compare different hull shapes. Also the methods for free surface calculation are various even for VOF, and I want to know which method and what accuracy(numerical order) are applied. If you know anything about this topic that would be very interesting, maybe about Star-CD, Fluent and Phoenix.
Thanks
Old   December 11, 2002, 08:30
Default Re: Free surface
Holidays
CFX has undertaken the implementation of a FS model (different from VOF) paid for by the Navy as far as I know.
Since then it has been used for the Americas's Cup by by the NZ defender, Kingfisher, SVA Postdam (Germany) and Qinetiq (UK MOD?) for submarine periscopes (I have seen this in the latest CFX magazine I have received) and this I know only from the CFX magazine. So it seems quite popular and used for ship hull resistance, spray etc... At the last conference I have attended they have presented FSI development work that allows the motion of the hull using the fluid information.
Personally I have only used the code for environmental purposes (river, weir and pump flows with FS). What you track is the fluid (or air) volume fraction (not a scalar) using a homogeneous model (you could also use true multiphase at a higher cost). Once you have started to converge you can switch on mesh adaption to refine the definition of the FS which is usually defined across three elements. You can use first and second order scheme.
I
Free surface is below than expected..results are not good mechovator CFX 24 April 8, 2011 01:41
Submarine Free Surface samwh CFX 7 August 30, 2009 08:14
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 17:14
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 22:03
