December 6, 2002, 06:14 |
backward facing-step
Hi all, Anyone can send me some experimental and/or numerical data concerning a backward facing-step laminar flow (Re vs reattachment distance).
Thanks a lot |
December 10, 2002, 07:56 |
Re: backward facing-step
Try the ercoftac data base it contains the DNS data for the paper 'Direct Numerical simulation of turbulent flow over a backward-facing step' by Le et al.
Stephen |
December 11, 2002, 20:07 |
I find one paper:"Simulation o fturbulent flow over a backward-facing step" J. Fluid Mech, 1997, vol.330:349-374
December 12, 2002, 04:44 |
http://ercoftac.mech.surrey.ac.uk/dns/homepage.html
maybe you can get some useful information from the web site. |
December 12, 2002, 14:20 |
Sophie, I wrote a FORTRAN program using finite volume method staggered grid pressure correction with SIMPLE algorithm as part of my cfd msc. The total pipe lenth was 171 units long (in the x direction). It expanded from 10 units (in the y direction) to 20 units (via a one sided step like the one you mean) at a distance of 20 units in the x direction. The fluid was water and it entered the pipe with a parabolic velocity with maximum in centre of 1.5 units per sec. The reatatchment distance was at about 64 units in the x direction (this is 64-20=44 units past the step).
Please say if my explanation of the Geomerty is rubbish. I will try again if you wish. Good luck, Rat. |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Backward facing step. | Fluids | Main CFD Forum | 7 | December 4, 2012 12:28 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
