gravity and boundary condition
Like Tree2Likes
Old   November 26, 2002, 08:58
Default Re: invisid no slip body condition
  #21
Tom
I'm not sure what fi is physically (I'm not familiar with the level set method) howeve you do not have enough boundary conditions to define your problem!
The flow is inviscid so that the wall condition is simply n.u = 0 where n is the normal to the wall ( in your case your wall appears to be vertical so n.u = U =0 - if your wall is horizontal you should have n.u = V=0). You cannot apply no-slip!
On your interface you need to prescibe the pressure in order to drive the flow ( along with suitable "inlet/outlet" bcs - your system is elliptic and so needs conditions on all boundaries)
I think you need to thoroughly check the mathematical definition of your problem to ensure it is completely self consistent,
Tom.
scleakey likes this.
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Boundary Condition in CFX ssbear CFX 5 February 7, 2011 02:10
Boundary Condition in CFX ssbear ANSYS 1 February 1, 2011 21:43
Outlet boundary condition for pd in InterFoam gopala OpenFOAM Running, Solving & CFD 0 March 19, 2008 10:26
