Turbulent model & NS
Old   November 13, 2002, 04:40
Default Turbulent model & NS
new one
Principally NS equations describe both turbulent and laminar flows. Then why in codes additional turbulence model information is required?
Thanks,
new one
Old   November 13, 2002, 05:17
Default Re: Turbulent model & NS
sheetal
The DNS of the turbulent flow is not possible with the current computing capabilities, since the realistic turbulent flow consist of large range of turbulent length and time scales. So it is necessary to reduce the complexity of the model. So RANS are introduced. RANS represents transportation equations for mean flow quantities instead of resolving turbulent fluctuations.
regards, Sheetal
Old   November 13, 2002, 07:05
mukhopadhyay
eqn of motion (popularly called ns eqn) describes flow in terms of the instantaneous velocity in a flow situation, the instantaneous vel is the combination of the time averaged component (mean flow) and the fluctuating component. thru reynold's decompostion (rans) one addresses the first one while the fluctuating component is addressed thru various turbulence propositions. a good understanding may be developed if you look at the book by anderson, tannehill and pletcher. dns is also possible and available now for many situations - formulation quite difficult and computation quite expensive although.
Old   November 13, 2002, 08:59
Holidays
DNS is only possible at small scale and low Re number, hence the need for LES or RANS version of the N-S eqns.
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 15:08
flat plate with turbulent model danielcebrian OpenFOAM 10 November 13, 2014 16:47
LamBremhorst turbulent model J0bouchard OpenFOAM 3 February 21, 2013 10:28
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Turbulent SST model fergal CFX 13 November 2, 2010 19:15
