memory problems with a code on unix
Old   November 4, 2002, 18:25
Default memory problems with a code on unix
vince
I want to run a fortran code on an unix station but the execution generate errors due to insufficient memory. I precise that during the run the code need to write many intermediate files.
I think I need to extend the swapping memory. What are the unix commande which can solve my problem?
vince
Old   November 5, 2002, 04:31
Default Re: memory problems with a code on unix
Rob
I would firstly check that you have access to all of the standard memory. Depending on how the machine is set up you might have an allocation of only part of the total memory for any one job. For example, on one multi-processor machine I use there is 1GB of RAM, but the default setting is only 250MB for any job, unless you tell it otherwise.
Try issuing the command
limit
and you should see a list of limits that can be set. In particular stacksize and memoryuse should be equal to the total memory available. To do this type
limit stacksize unlimited limit memoryuse unlimited
If you really need to use virtual memory then I think this can also be set with the command
limit vmemoryuse unlimited
but beware of using so much virtual memory that you can no longer write to disk.
Old   November 5, 2002, 04:48
Default Re: memory problems with a code on unix - cont.
Rob
Sorry - message hasn't appeared quite as planned.
The commands
and
should by typed separately.
From 2D compressible code to 3D code David Liu Main CFD Forum 22 June 26, 2012 18:59
Memory Problems David Baker Siemens 5 March 1, 2007 22:04
Problems with dynamic memory allocation Syed Siemens 0 July 23, 2006 13:02
Moving Mesh Problem in Unix Platform Arnab Siemens 3 August 16, 2004 09:59
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 23:55
