Turbulence boundary values
Old   October 24, 2002, 14:47
Default Turbulence boundary values
lego
Hi!
I need your suggestion which kind of turbulence boundary condition to be used. I calculate flow field and mixing between heated rod bundles. I already have a result file, and I would like to set the inlet turbulence parameters for a new run on the basis of the outlet results of this previous calculation. I use the k-Omega turbulence model.
I can export the following turbulence parameter values:
Eddy Viscosity [kg /m/s] Shear Strain Rate [1/s] Turbulence Eddy Dissipation [1/m2/s3] Turbulence Eddy Frequency [1/s] Turbulence Kinetic Energy [1/m2/s2]
And I can set as input parameter the followings:
Turbulent Intensity and Eddy Viscosity Ratio [dimensionless], [dimensionless] k and Epsilon [1/m2/s2], [1/m2/s3] Turbulent Intensity and Eddy Length Scale [dimensionless], [m]
My problem is that I have a detailed result, but I can set only AVERAGE values. And for example in case the Turbulence Kinetic Energy (k) the values near the wall is much different than it is in the main flow.
Which type of setting should I use? And how can I calculate these parameters from the parameters, which can be exported? (For example Eddy Viscosity Ratio = Eddy Viscosity/Dynamic Viscosity)
Thanx: LEGO
boundary values OFU OpenFOAM Programming & Development 4 August 9, 2011 07:27
Recommended values on turbulence B.C. Jihwan Siemens 2 August 10, 2005 08:45
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 16:39
