We purchased horizontal Francis Turbine from Voith in past. Now we want to do simulation of its rotor. Firstly we want to calculate different parameters of turbine and then simulation and redesigning of runner and then again calculation of different parameters. If any one is using Horizontal Francis turbine please contact me so that i could know how to calculate different parameters like flow, power, efficiency, tourqe, specific speed. thanks
A google search using "Francis turbine" gives these hits plus others.
1. [PDF]Complete Francis Turbine Flow Simulation using Fluent www.simtec.gr/fluent_downloads/Carija_Zoran.pdf - 2. Forum Question: "francis turbine " ... francis turbine " www.efunda.com/forum/ 3. Flow through an entire Francis turbine ... 1999. New Insight into an old product by high performance computing, Simulation of the flow through an entire Francis turbine. M. Heitele ... www.cineca.it/mpp-workshop/abstract/ruprecht.htm - 5k - Cached - Similar pages |
Thanks very much for your help But from all these information still i haven't got the method of designing of francis turbine. but i have emailed all of them about them you informed me. If you have any further information and you have any soft copy of Francis Turbine designing Method please send me. Do you know about surge tank its function and designing. Thanks again
Recommend YOU do a google search (www.google.com) using "Francis turbine surge tank" - lots of hits - pick what you want.
Arslan
Rep Power: 15 ![]() |
Hi mukkarum;
I has been too much time since your last post but i wanted to give it a try. I am working on Francis turbine design and had some progress. We might do some work together. Send me a message for further talk. Best regards. |
GAMM Francis Turbine | Mukkarum | FLUENT | 2 | March 22, 2014 11:26 |
Hardware Requirement For Francis Turbine Simulation | chiragsvnit | Hardware | 5 | January 10, 2012 00:41 |
Horizontal Francis Turbine | mukkarum | Main CFD Forum | 0 | October 15, 2002 06:03 |
Francis Turbine | mukkarum | Main CFD Forum | 2 | October 14, 2002 00:58 |
Francis Turbine | mukkarum | FLUENT | 6 | July 24, 2002 05:01 |
