Transonic small disturbance equation
Old   July 16, 1998, 15:44
Default Transonic small disturbance equation
Kaveh Ghayour
Simple upwinding for the hyperbolic points in the TSD equation( Transonic small disturbance) leads to a first order accurate scheme in the supersonic region. Can anybody help me with making this scheme second order accurate for the aforementioned region. Thanks a lot.
Old   July 26, 1998, 06:23
Default Re: Transonic small disturbance equation
A.Durante
Hi, I'm also working on TSD equation. I think you need a type-dependent mixed difference scheme so I send you via separate E-Mail the second-order Engquist-Osher scheme for the streamwise term of TSDE. This scheme is central in the subsonic region and backward (upwind) in supersonic region. I'd like to know if you are working on Unsteady TSDE or if you have any general test cases.
rotational and inviscid Mike Main CFD Forum 40 November 9, 2023 07:03
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
continuity equation Rafal Main CFD Forum 4 November 29, 2006 10:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 09:14
