ultrahigh pressure water jet
Old   September 25, 2002, 06:08
Default ultrahigh pressure water jet
kaiser
I wanna simulate ultra high pressure water jet under submerge condition.who will give me some advice on the model selection and the water parameters? and also how to settle the B.C? Thanx
Old   September 25, 2002, 22:00
Default Re: ultrahigh pressure water jet
Junseok Kim
I am investigating liquid/liquid jet, what do you mean by ultra high pressure water jet?
You may see the simulation results and related experimental data.
http://www.ima.umn.edu/~junkim/jet.htm
Old   September 25, 2002, 22:32
kaiser
The ultra high pressure water jet means usings pumps and intensifies to produce about 200MPa water jet under water.My headache is selecting what model to simulate it, for water under such a high pressure will becoming different from ordinary water.If employ k¨C¨C¦Å equations, then the volume changment was omissioned, if take the volume compressiablity into account ,then how to modify the equations to validate them? Looking forward to receiving your guidelines soon!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Help!simulation of free water jet Annie FLUENT 3 June 29, 2009 01:51
How to simulate the water hammer pressure. arwang FLUENT 0 March 12, 2007 08:07
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
