Radiation
Old   September 27, 2002, 23:10
Default Re: Radiation
  #21
Adam Wu
Hi Rami,
I have found your published paper and I will certainly go through it. But just from the abstract of your paper, it seems that the paper apply DOTS on radiative transport equation (RTE) . So my question is in a situation of fluid medium which is not participating or in other word, the medium is transparent to the thermal radiation, then radiative heat flux term should not be appeared in the energy equation of the fluid (but the heat energy will get in the fluid through the conduction at the solid-fluid interfaces), how can you apply DOTS/DOM method to solve RTE (when RTE is not existed at all)?
Well, I understand that DOM is a purely mathematical method for solveing integral-differential equation, and it is not limited in solving RTE. I believe it should have no problem to use it to solve the transport equations of the fluid. But specifically to the radiation exchange between solid boundaries with only non-participating medium involved, would you please explain a little bit more detail on how you apply the DOM/DOTS in solving RTE?
Regards,
Adam
Old   September 29, 2002, 03:41
  #22
Rami
Hi Adam,
I suspect this discussion becomes too specific and would not be of interest to most of this forum audience. I therefore suggest we continue through e-mail.
However, just a short answer to your question: we use the DOM merely to solve the radiative transfer equation for given temperature. The resulting net radiative source is applied as a source term to the fluid and at boundaries. The fluid equations are solved (including coupling terms, e.g., volumetric convetive HT) and new fluid and solid temperatures are estimated. This iterative process is continued until converged.
PS., we did not publish this method yet, and it is certainly beyond the scope of the paper I mentioned. If you are interested, I will e-mail you more details.
Old   January 6, 2013, 03:23
morteza
yoollooz is on a distinguished road
hi friends
i want to calculate radiation heat transfer by zone method.
i have all formula but i dont know any thing about udf.
please help me.
yoollooz is offline   Reply With Quote
Old   January 9, 2013, 04:29
Default Radiation Studies : docsity.com
  #24
Maria
Maria3344 is on a distinguished road
Radiations are an important topic in the current world of nuclear devices. This document might help you in studying this process.
http://in.docsity.com/en-docs/Physic...Lecture+Slides
Maria3344 is offline   Reply With Quote
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
Surface incident radiation Pipiola FLUENT 0 August 11, 2009 16:46
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 04:51
Radiation: definitions visatron CFX 7 January 8, 2004 16:25
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
