Mixture Properties
Old   September 18, 2002, 03:36
Default Mixture Properties
Theju
Hello, I want properties of a gas mixture ( of H2, CH4, N2, CO,CO2,H20 of known molal concentrations ). Can I find this info online. Thanks in advance.
Regards Theju
Old   September 18, 2002, 07:02
Default Re: Mixture Properties
Rami
Hi Theju,
You may easily calculate it using software such as Sandia's CHEMKIN. Version II (1994 revision) is free and may be downloaded from the web, including the source code and documentation. Later versions may be purchased from Reaction Design. I guess you won't need the latest version, though, and may calculate what you need with the free version.
Actually, most of the properties calculations are trivial, and may be done in a spreadsheet if you have the JANNAF thermodynamics (or similar) database.
Rami
Old   September 18, 2002, 07:16
Theju
Thanks for the reply Rami. Can you please pass on the URL for downloading?
Regards Theju
Old   September 18, 2002, 07:25
Rami
I am not sure where it is now. It is no longer where it used to be. If you wish I may send it to you by e-mail (as attachment). It is about 5Mb uncompressed, and I can WinZip it.
Old   September 18, 2002, 07:33
Theju
Please send it through email . Thanks for the quick reply Rami.
Regards Theju
Old   September 18, 2002, 08:00
xingqiuYuan
Hi:
can you send me a copy of it, I need the properties (mixture of H2 and C2H2 etc) to use. the temperature is up to 30000k.
if you can send me ,please send this mail: plasmachina@yahoo.com.cn
thanks in advance.
Old   September 18, 2002, 12:14
cfd
Hi Rami
hve you done any work in a mixture two-phase flow (gas-liquid) through a NOZZLE.
Old   September 29, 2002, 03:01
Rami
> Hi Rami
: hve you done any work in a mixture two-phase flow (gas-liquid) through a NOZZLE.
No, sorry.
variable composition mixture properties Neser25 CFX 6 August 17, 2020 15:19
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
Gas mixture thermo properties guy_smiling OpenFOAM 0 March 11, 2011 22:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
