Flotran problems with compressible turbulent flows |
September 10, 2002, 18:47 |
Has anyone tried the ANSYS Flotran compressible turbulent example in 6.0? Their own example will not converge on a solution! I ran the example from a text file copy and pasted from their documentation????
What i'm trying to do is run a compressible turbulent flat plate model. No mater what I seem to do I cannot get ansys to converge on an answer. I looked at their example, and lo and behold I get the same problem. Anyone with Flotran experience that can lend a hand? Ross Stilling rstillin@vt.edu |
September 27, 2002, 14:08 |
Re: Flotran problems with compressible turbulent f
Ross I used a very old version of the code back in 1995. What is the example they use ?? is it 2D flow over a NACA 0012 wing section Mach 2.0 ?? Dave
time step for turbulent flows | vishnu | FLUENT | 0 | December 13, 2006 02:28 |
PDF Model in compressible flows with shock waves | Hanxsi | FLUENT | 0 | February 26, 2006 21:51 |
FVM (vs) FDM for compressible flows | Rajani Kumar Akula | Main CFD Forum | 6 | April 12, 2002 02:56 |
Problems with convergence and initial guessed fields in compressible steady flows | Pedro Gil | Main CFD Forum | 3 | April 25, 2000 12:34 |
