Explicit filtering in LES
Like Tree27Likes
Old   November 30, 2016, 05:21
callahance is on a distinguished road
How can I do this ? If I have the field only on the fine 128 grid, how can I map this field on the 64 grid without smoothing ? Each coarse cell on the 64 grid has to get a value from 8 fine cells. Averaging all 8 cells is the logical method to me.
callahance is offline   Reply With Quote
Old   November 30, 2016, 05:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Just select one node each two somehow similar to the multi grid procedure
FMDenaro is offline   Reply With Quote
Old   November 30, 2016, 05:39
lets take a simple 2D example. How would you calculate the value in the bigger cell based on the values of the fine cells (1,2,3,4) ?
Old   November 30, 2016, 05:48
No You should consider Nyquist theorem and the simplest 2D example requires a 4x4 grid to be sampled on a 2x2 grid
Old   November 30, 2016, 06:11
which would look like this ...
Old   November 30, 2016, 06:22
well, I was thinking about a 4x4 mesh of size h with values at grid intersection (5x5 values) not at the center of the cells but we can work also on this figure you have done.
Consider the nodes structured as i=1:5 and j=1:5 at step h. You select the node (2,2), (4,2), (2,4),(4,4) and you have the coarser grid represented by a 2x2 mesh of size 2h. Periodicity completes the construction of the coarse grid.
LES explicit filtering maka OpenFOAM Running, Solving & CFD 4 December 27, 2012 10:08
LES explicit filtering Paul Main CFD Forum 0 March 17, 2006 09:03
LES (explicit) filtering John Main CFD Forum 2 July 29, 2004 19:03
Channel LES and explicit filtering Luca Liberti Main CFD Forum 0 January 17, 1999 11:07
