Nu value of 2-D Channel
Old   September 5, 2002, 08:10
Default Nu value of 2-D Channel
Cahtterjee
Where can I found the value of Nu for a 2-D channel.
I want to Nu for Re=40,000 based on double the channel height (2H) or 20,000 (based on charac lenght H)
Old   September 5, 2002, 11:20
Default Re: Nu value of 2-D Channel
Rami
You'll find it in any standard heat transfer textbook (e.g., Holman, Ozisik, etc.). For tubulent flow, it is usually given as correlations in the form:
Nu = c * Re^m * Pr^n
where Re and Pr are Reynolds and Prandtl numbers, and c, m, n are the correlation parameters.
Old   September 5, 2002, 13:35
Simmons
but if it is a mixed convection case, add Gr in the corelation formula. you can find this in any heat transfer book.
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 17:26
Open channel flow motaba Main CFD Forum 4 March 26, 2011 04:22
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 21:03
About Cooling channel alefem FLOW-3D 1 May 28, 2010 12:15
Open Channel Boundary Conditions via journal Matteo FLUENT 0 January 21, 2008 12:05
