Time Stepping
Old   September 4, 2002, 19:03
Default Time Stepping
Chan K I
I am a running an internal flow time-marching simulation using Jameson's Runge-Kutta scheme.
At different CFL numbers, the converged solution is different. Any ideas what could be the problem?
Thanks very much Chan K I
Old   September 5, 2002, 03:05
Default Re: Time Stepping
Tom
You are sure that the implimentation of the Jameson scheme is correct? Perhaps you can test your code with a well defined (laminar) problem.
Tom
Old   September 5, 2002, 12:22
Chan K I
Hi Tom,
Thanks for your reply.
The scheme has been well-assessed beforehand and is being implemented on an internal flow case.
Old   September 6, 2002, 17:07
Pao
Are you running the transient solution? or steady state solution?
Old   September 6, 2002, 18:30
Chan K I
Hi Pao,
I am running a time-marching solution to a steady-state.
Noticed that with same initial conditions, different time steps give different steady-state solutions.
Thanks very much
Old   September 6, 2002, 18:36
Pao
But after a long iteration, the steady state solution is independent from the time step. This is my experience.
Old   September 7, 2002, 05:50
versi
You may encouter MULTIPLE solutions for an encolsed region, if Re is high enough. This is physically possible. For example, Spherical Coutte flow may have 0-vortex, 1-vortex and 3-vortex flows at the same Re number. Please specify your flow problem in detail.
Old   September 7, 2002, 10:51
Jim Park
As early as 1972, Pat Roache published a study showing multiple (steady state) numerical solutions for the same physical problem as he changed the time step.
Try Roache, Patrick J., "On Artificial Viscosity," Journal of Computational Physics, Vol 10, No. 2, October, 1972.
Old   September 8, 2002, 15:43
Chan K I
Hi guys,
Thanks so much for your comments!
Pao: The small time step calculation has been run for a reeally long time and the observed trend for mass flow (this is an internal flow problem) shows it converges to a smaller value than for the large time step case.
Versi: This is a time-marching solution to the compressible Euler equations. Hence Re can be taken to be infinity.
Jim: Am going to browse through the paper.
Any more ideas out there?
Cheers
Old   September 9, 2002, 11:44
Pao
How about the external flow calculation? Did you see time step affect the solution? Or this only happen for internal flow problem?
Old   September 10, 2002, 11:05
  #11
Chan K I
The code was developed for internal flow cases. Previous internal flow simulations did not yield the problem. Only encountered it recently.
Cheers
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
Dual TIme Stepping Daniel Main CFD Forum 3 March 16, 2005 21:14
