curvature
Old   September 3, 2002, 23:25
Default curvature
x.zhang
Hi, there:
Does anybody know how to calculate the curvature of a convolution surface?
Thanks.
Old   September 3, 2002, 23:32
Default sorry ,I post it again!
x.zhang
sorry,
The question should be:
Does anybody know how to calculate the curvature of a "revolution" surface?
Old   September 4, 2002, 03:39
Default Re: sorry ,I post it again!
versi
curvature in the rotational direction: 1/r, where r is the radius of the body (the distance from body surface to the rotational axis); curvature in the azimutal plane: Know the first and second derivatives first, then compute curvature according to a standard formula;
curvature = div ( N ), where is the unit normal vector.
Old   September 4, 2002, 07:04
Student.
Try using the following in Google as search terms
"curvature of a revolution surface" ......leave out the quotes when using Google.
Old   September 4, 2002, 23:24
x.zhang
I think you are wrong. I have thought it over before I come here for help!
1/r is not the curvature in any direction!!!
e.g. When a hemi-circle rotate, a sphere is formed. I think now you know what I mean.
Old   September 4, 2002, 23:59
versi
r is not necessarily radius of revolution. There are two principal radi of cuvature for a general surface in 3D space. Refer to a book on geometry.
Old   September 24, 2002, 11:28
Tom
If you write your surface as z = f(r) where r is the radius, then the curvature is f''/sqrt(1 + f'^2) where ' = d/dr. ( If you have r = g(z) then the formulas just the same; g''/sqrt(1 + g'^2) '=d/dz ).
Old   September 24, 2002, 12:17
Tom
Oops!! the square root should by a power 3/2; i.e. the cude of the square root.
strange curvature with interFoam (comparison with Brackbill work) duongquaphim OpenFOAM Running, Solving & CFD 23 July 25, 2013 02:03
sharp interface and curvature yukn Main CFD Forum 0 October 12, 2011 13:54
How to use SST Curvature Correction mike wilson CFX 11 December 19, 2010 17:04
Curvature Effects using the Standard K Epsilon Model syler3321 CFX 2 October 19, 2010 21:53
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 09:08
