ENO scheme (ENO-Roe) (Shu and Osher).
Old   September 3, 2002, 10:44
Default ENO scheme (ENO-Roe) (Shu and Osher).
J. K.
HI all,
I have a question regarding the ENO scheme. I have been trying to implement an ENO's scheme based on Shu and Osher's paper "ENO and WENO shock capturing schemes II" , Journal of Computational Physics, 83, 32-78 (1989). Now, it seems that this method is used when operating on cell centre values. I want to use cell averages. When I look at Laney's book, "Computational GasDynamics", on page 524 he states that "...in one interpretation, f(u(subscript i, superscript n)) is a cell-integral average of f(x)", where f(x) is the f^hat numerical flux. Laney's scheme in his book is Shu and Osher's scheme. This suggests that cell averages can be used. Can someone explain the apparent paradox between the use of cell averages and cell- centred values? I am missing something here!! I hope!
Regards,
J.
Old   September 3, 2002, 18:04
Default Re: ENO scheme (ENO-Roe) (Shu and Osher).
Bert Laney
I'm not sure I understand your question. The Shu-Osher ENO method is a finite-difference method, i.e., it approximates cell-centered values of the solution. The derivation given in my book, which involves cell-averages of the flux function, doesn't imply that the Shu-Osher ENO method is finite-volume. If you want a finite-volume method, you'll have to use the original ENO method.
In one dimension, the cell-centered value of the solution is a second-order approximation to the cell-integral average. Thus, if you can be content with second order accuracy, you can consider any finite-difference method to be finite-volume if you like (in one dimension).
Hope this helps.
Bert Laney
Old   September 4, 2002, 07:01
J. K.
Hi Bert.
Thanks for your reply.
I am aware that a cell-centered value of a solution is a 2nd order approximation to a cell-integral (=finite volume?) average. However, I was hoping to achieve 3rd order accuracy. I would also like to extend the method to 3D.
I was under the impression that a cell-average was the same as finite volume, I take it I was wrong?!
Finite volume, cell-integral and cell-average all seem pretty similar to me?
Why are there problems when extending to more than 1-dimension?
Will the original ENO scheme will work well in 3 dimensions?
Thanks again,
Regards.
J.
Old   September 14, 2002, 03:32
gmreszhao@163.com
Dear J.K:
There is a paper of Chi-Wang Shu, "Essentially Non-Oscillatory and Weighted Essentially Non-Oscillatory Schemes for Hyperbolic Conservation Laws", NASA CR-97-206253 ICASE Report No. 97-65. It can tell you how to implement three or more oder of accuracy of ENO or WENO in FV for a 3d problem. You can download it from http://www.icase.edu/library/reports/rdp/1997.html.
Good luck to you!
Zhao
Old   September 17, 2002, 08:15
autofly
I have finished the ENO scheme FV in two dimensions.very difficult. if you want to get higher order than 2nd,you must do some effort to understand the reconstruction for two varriables.not simple dimension splitting technology,you must consider the cross-term.welcome to disscuss with me.
Old   February 19, 2013, 18:00
Default Eno
rachna
kika is on a distinguished road
I am trying to write the matlab code for eno but I am unable to do
for i=2:nx-2
k=i-1;
p1(i)=D1(k);
if abs(D2(k+1))<= abs(D2(k+2))
p2(i)=(2*(k-i)+1)*D2(k+1);
else
p2(i)=(2*(k-i)+1)*D2(k+2);
end
Q=p1+p2;
end
for i=2:nx-2
l=i;
p11(i)=D1(l);
if abs(D2(l+1))<= abs(D2(l+2))
p22(i)=(2*(l-i)+1)*D2(l+1);
else
p22(i)=(2*(l-i)+1)*D2(l+2);
end
P=p11+p22;
end
for i=1:nx-2
V1(i+1)=Q(i);
end
for n=1:nt
for i=2:nx-2
V(n+1,j)=V(n,j)-Dt*V1(n,j)
i dont know what is wrong here
I tried can u please suggest me something
kika is offline   Reply With Quote
Old   February 21, 2013, 15:55
Jonny
Jonny6001 is on a distinguished road
I am curious as to the difficulties that you talk of "autofly" when using the ENO scheme. It is a straight-forward scheme.
I would certainly opt for WENO schemes if you can deal with the increase in solver time.
Regarding the original post, the question entirely depends on your interpretation of the terms. The ENO scheme simply selects the smoothest polynomial to calculate the inter-cell flux values when it comes to FV methods.
Jonny6001 is offline   Reply With Quote
Old   March 28, 2013, 09:08
Default Eno
rachna
for example I am solving advection equation u_t+ au_x=0
and with initial data u(x,0)= 0.5-|x| if |x|<= 0.5
= 0 else
okay so I am using ENO via primitive function so I have calulated the average
1) for j=1:nx+3
x(j)=-1-dx+(j-1)*dx;
u0(j)=(u_0(x(j)+(dx/2))+u_0(x(j)) + u_0(x(j)-(dx/2)))/3;
end%
2) the scheme becomes u_{j}^{n+1} = u_{j}^{n}- (f_{j+1/2}- f_{j-1/2}).
3) f_{j+1/2} i sthe numercial flux and now I am calculating numerical flux by Lax- friendrich (as u can see in the article of shu page number 355)
f_{j+1/2}= h(u-_{j+1/2}, u+_{j-1/2}).
h(a,b)= (1/2)(f(a)+f(b)-alpha(b-a)).
[since this is for u_t+ (f(u(x,t)))_x=0 ]
so my f(u)= au.
so my f_{j+1/2}=a u-_j+1/2.
so for calculating f_{j-1/2 } i put j=j-1 so f_{j+1/2}= au-_j-1/2.
and as in the shu article
u-_j+1/2= p_(i)(x_{i+1/2})
so for calculating u-_j-1/2= p_(i-1)(x_{i-1/2})
I mean polynomail changes, and I am using the code for calculating this polynomail
function y = back(u,nx,x,dx)
y(1)=0;
y(nx+3)=0;
for i=1:nx+3
a(i,1)=u(i)
end
for i=2:nx+2
a(i,2)=(a(i,1)-a(i-1,1))/(x(i)-x(i-1))
end
for i=2:nx+2
if abs(a(i,2)) < abs(a(i+1,2))
a1(i)=a(i,2)/2
else
a1(i)=a(i+1,2)/2
end
y(i)=u(i)+a1(i)*(x-x(i));
end
end
so in above function when i put x=x(i)+(dx/2)
for claulating the polynomial p(i-1) I ahev tried many things but my scheme is not correct I can see very bad behaviour near the kink.
I am really tired with this.
Please suggets me something where I am wrong
Old   March 28, 2013, 09:09
rachna
Please soemone try to answer me and if possible please answer em soon
= 0 else
1) for j=1:nx+3
end%
so my f(u)= au.
y(1)=0;
y(nx+3)=0;
for i=1:nx+3
a(i,1)=u(i)
end
for i=2:nx+2
end
for i=2:nx+2
a1(i)=a(i,2)/2
else
a1(i)=a(i+1,2)/2
end
end
end
ENO scheme: (Shu and Osher) J. K Main CFD Forum 3 July 18, 2002 13:51
