May 22, 2010, 16:55 |
#21 |
t_shirt
Rep Power: 16 |
If anybosdy has NASA Rotor 67 geometry in soft copy, data poins. Kidly send me at samahmedpk2000@yahoo.com Regards, |
June 25, 2010, 18:06 |
#22 |
Saima
Rep Power: 16 |
I have developed a code in MATLAB for NASA rotor 67 2D Profile by using a paper i am going to attache both of them, but my blade profile is very sharp i want to know is this shape logical?
Note: Read page number 3 and 8 for blade shape parametrization Thank you and Regards, |
June 25, 2010, 18:14 |
#23 |
Saima
Rep Power: 16 |
Here is blade profile from MATLAB.
June 26, 2010, 21:47 |
NASA Rotor 67 Geometry
#24 |
t_shirt
Rep Power: 16 |
Hi All,
I have type all geometry of Rotor 67 in excel. Hope It will help u out. I took from :http://ntrs.nasa.gov/archive/nasa/ca...1987007372.pdf Page: 182-184 Regards, |
August 7, 2010, 14:50 |
rotor 37 and 67
#25 |
N.Re.
Rep Power: 16 |
Hi all,
Does anybody have the geometry data of rotor 37 and 67 ? the existed links doesn't work and would you please mail them to n.rezaee.gh@gmail.com Thanks. |
August 26, 2010, 01:23 |
nasa rotor 37
#26 |
sajad asadzadeh
Dear all,
I need nasa rotor 37 or one Gas turbine compressor (Axial) such as SIEMENS gas turbines , geometry. best regards |
August 26, 2010, 01:58 |
#27 | |
sajad asadzadeh
Hi
This Link failed and not work please send me corrected link. my E-Mail Address: sajad@asadzadeh@gmail.com best Regard Quote:
September 14, 2010, 23:57 |
#28 |
N.Re.
Rep Power: 16 |
Dear All,
I read the NASA report "NASA-TP-2879-Laser Anemometer Measurements in a Transonic Axial Flow Fan Rotor" that is generated for NASA rotor 67,but I can not produce the geometry of the blade from the data given in this report. Does anybody have better data for producing NASA rotor 67 in a CAD software like solidworks or catia? I appreciate if you send the geometrical data to n.rezaee.gh@gmail.com Thanks Last edited by annie; September 14, 2010 at 23:58. Reason: adding email |
September 15, 2010, 00:11 |
question?
#29 | |
N.Re.
Rep Power: 16 |
but the shape of sections 1,2,3 didn't have appropriate shape;and the other sections was almost good. Could you please tell me where did you extract these data from? |
October 6, 2010, 03:32 |
thick blade
#30 |
hamedpotter
HI ,EVERY BODY
I 'M LOOKING FOR A THICK BLADE geometry. Thanks. |
December 22, 2010, 21:08 |
#31 |
huo guilong
Dear all,
I need the geometric data of S67 and data surface of literature.If you have ,please send it to my mailbox:long.123@stu.xjtu.edu.cn.I would be very thankful to you. |
January 19, 2011, 05:45 |
#32 | |
Devraj Dutt
Rep Power: 15 |
Go here. on the bottom right, click HTTP. That should do it |
January 22, 2011, 17:04 |
#33 |
m p
Rep Power: 15 |
To All Of You
here's a good file on rotor 67 geometry, it has also got the space between tip and casing and ... enjoy a complete 3d grid! http://aero-comlab.stanford.edu/vdwe...ModTipGap.cgns |
February 2, 2011, 16:19 |
rotor geometry and performance
#34 |
m p
Rep Power: 15 |
Also if you want to work on rotor 35, rotor 36 , rotor 37 or rotor 38, here are two reports that will help. one contains geomety in easy format.They also contain information of the stators and performance of stages.
go to nasa site ntrs.nasa.gov and search these: 19780025165 19790001889 |
April 2, 2011, 16:44 |
need help with splitting the mesh file
#35 |
Amool A Raina
Rep Power: 16 |
Hey moein_joon27,
I am trying to split my mesh file that I generated using tcgrid for nasa rotor 67. How did u split your mesh? Could u please send me the details asap? Thanks a ton!! |
April 6, 2011, 14:34 |
#36 |
m p
Rep Power: 15 |
In that time, I just needed one section of the rotor. I used Techplot, It can show different parts of the file. I chose the rotor surface and then made a section. I didn't see Techplot extract any good data, so I picked up some points from the shown section.
July 29, 2011, 01:50 |
NASA ROTOR 37 geom
#37 |
Rajpal singh bhadoria
Anybody can send me the .igs or .tin or any formet of nasa rotor 37 blade geometry..my mail ID is rsbhadoria@jetmail.ada.gov.in..
i would be very thankful... |
November 1, 2011, 14:05 |
#38 |
Rafiee
Rep Power: 15 |
Dear all
I am looking for stator of nasa 67 ... It seems that is would be in the following nasa article but unfortunately I couldn't download it ... Does anyone has it? Thanks in advance NASA Technical Memorandum 88929 Unsteady Flows in a Single-Stage Transonic Axial-Flow Fan Stator Row Michael D. Hathaway |
April 25, 2012, 05:46 |
#39 | |
Ales Prachar
Rep Power: 15 |
April 25, 2012, 07:49 |
#40 |
Rafiee
Rep Power: 15 |
I couldn't succeed with this grid ... I generated my own mesh ... I created the geometry by ansys bladegen, then I used turbo grid to create structured mesh and creating shroud gap
NASA Rotor 37 Boundary Condition Problems | Dom | FLUENT | 1 | March 27, 2012 07:00 |
nasa rotor 67-blind case for cfd | sam | FLUENT | 2 | April 3, 2011 15:04 |
can i get geometry of nasa rotor 67 from fluent | alex marshall | FLUENT | 0 | March 27, 2006 04:20 |
NASA Rotor 67 Geometry | alex marshall | Main CFD Forum | 2 | March 27, 2006 04:02 |
NASA rotor-xxx grid file | cfd_fan | Main CFD Forum | 0 | January 12, 2005 19:22 |
