Implicit scheme for incompressible flow problems
Old   August 10, 2002, 12:00
Default Implicit scheme for incompressible flow problems
Triton
I'm solving incomprssible Navier-Stokes equations with artificial compressibilty method. In order to use large pesudo time step, I use implicit scheme to integral in time. The converged solution, where all the dq terms drop to machine zero, is found to be dependent on cfl number. Is this normal? If there are any problems, what could the problems be?
Old   August 12, 2002, 23:59
Default Re: Implicit scheme for incompressible flow proble
versi
Solutions of some schemes such as Macormack, Strang type splitting, really dependent on time step. You will be required to give specific scheme used so that others can answer you.
Old   August 16, 2002, 09:22
j.p.rao pasupuleti
Old   August 24, 2002, 10:45
Andy Froncioni
The answer is: when you have reduced the time step to the point where your solution no longer changes much, you will have properly modeled your system.
It is vitally important to make sure that your solutions are properly converged in time and in space.
Implicit schemes guarantee stability, not accuracy, in time.
Old   August 25, 2002, 05:54
roro
what is the problem you are working for?
Maybe the problem is sensitive to disturbence.
Implicit Residual Smooth of Jameson Scheme hhuang84 Main CFD Forum 0 November 7, 2010 10:44
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 03:18
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 12:56
unsteady flow problems Daniel FLUENT 0 January 26, 2009 00:54
High speed flow problems Sawa FLUENT 3 January 14, 2003 02:10
