How to plot streamline with panel method?
Old   August 8, 2002, 06:04
Default How to plot streamline with panel method?
Fluman
I am now studying with panel method. I always wonder if I can plot the streamline with this method.Then I have a try as follows:
1.Outputs the doublet strength on body surface and wake surface,and the source strength on body surface.
2.Generates a body-fixed grid and calculates the velocity induced by all the doublets and sources at each point.
Finally,I have plot out the beautiful streamline .But I also found that,the induced normal velocity at the body surface didn't equal to the body moving normal velocity.So the streamline is not reasonable.Who can tell me why?
Old   August 8, 2002, 10:26
Default Re: How to plot streamline with panel method?
Peter Attar
The boundary condition states that n dot (q-q_b)=0 where n is the normal vector q is the fluid velocity and q_b is the body velocity. If you set your equations up correctly the velocity on the solid boundary at the point on your panel where you are solving your equations should be equal and oppsite in sign to the velocity of the flow normal to the surface at that same point. Are you sure you are finding your influence coefficients correctly?
Old   June 2, 2014, 06:51
Hari
prat_24 is on a distinguished road
Fluman,
Even i am using a panel method code, can u please explain in detail how did u plot streamlines i.e the set of commands used. i have used "meshgrid" command in MATLAB to generate the body fitted grid and used streamline(X,Y,U,V) command in matlab to plot but i get some weird pictures.It would be useful if u could give a detailed description.
prat_24 is offline   Reply With Quote
Help! 3d hess smith panel method zhongyu Main CFD Forum 18 December 19, 2013 14:15
Plot streamline by Tecplot aiqch Tecplot 0 June 15, 2009 21:57
Is it possible to plot streamline on a user surface fkzstar CFX 2 April 8, 2009 06:30
Why use a panel method? gocarts Main CFD Forum 2 April 22, 2007 23:50
Panel method problem niavarani Main CFD Forum 1 June 17, 2003 11:01
