Flow between parrall plates entry length formual? |
I am trying to compare the solution of the problem of laminar flow between parrallel plates with pressure gradiance using CFD pacakges and theory. I want to know where can I find the formula of the entry length (the length at which the flow reaches it's full development state). I found this formula for pipes in many reference of fluid mechanics but I didn't for the parrallel plates. If anybody can help I would be gratefull. S. S. Mudathir
Thank you very much, no need to answer this question because I got the answer. It is found in shilchting.
#3 | |
YAN YUE
Rep Power: 12 ![]() |
I want to know where can I find the formula of the entry length. Please, thank U! |
shahrooz
Rep Power: 15 ![]() |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
you can estimate in a very simple way, just use the laminar boundary layer law delta=delta(x) from some of those in literature and fix the condition delta=H/2 to estimate the corresponding x.
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
length scales at inlet for internal flows | Anne-Marie Giroux | Main CFD Forum | 3 | July 5, 1999 21:28 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
