July 20, 2002, 03:51 |
Viscosity Variation for Compressible Flow
Can somebody tell me how the relaxation factors for viscosity etc are varied.....Because i am unable to get the convergence for a compressible flow on an airfoil...Thanking in advance.. Durrani
July 22, 2002, 09:48 |
Re: Viscosity Variation for Compressible Flow
1) Why do you think that the viscosity is the main reason why you are not able to get a converged solution?
2) If I were you, I would try to solve the problem with a constant viscosity (vue at infinity), to ease the problem. 3) Usually, you don't need such a relaxation parameter for the viscosity. Poor convergence behavior may be caused by many factors, the main ones are: - CFL too large - bad mesh - wrong BC's |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
reversed flow... turbulence viscosity limitted ... | Babu | FLUENT | 3 | February 26, 2005 08:05 |
Vertical eddy viscosity in channal flow? | Liu | Main CFD Forum | 0 | June 15, 2004 22:07 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
