CFL number and time accuracy for LES
Old   July 19, 2002, 06:05
Default CFL number and time accuracy for LES
Li Yang
Dear all,
I am now doing LES using SIMPLE based solver. I use the Crank-Nicolson scheme in time and the central difference scheme in space. I would like to use the fully implicit scheme in time as well.
My questions are: (1) Which scheme would allow me to use a larger CFL number and how large a CFL number you normally used? (2) How do I know my solution is time accurate ?
Thank you very much in advance.
Li
Old   July 28, 2002, 03:47
Default Re: CFL number and time accuracy for LES
baal
hello,i finished the code of les program with fortran,and i use implicit scheme,but when cfl is 1.22,the convergent rate is very small,could you help me?thanks
Old   August 1, 2002, 07:11
adarsh
for implicit schemes any CFL can lead you to convergence .Cfl nos up to 20 has been used.but the accuracy of solution goes down as CFL no. increases.For time accuracy u can also use jameson's method of false time stepping.
but if the samllest time scale of the flow as given by kolmogorov scales is less , the it becomes a restricting factor and convergence can be affected.
hope this helps Adarsh
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
