Wall function application
Old   June 27, 2002, 20:57
Default Wall function application
Ola
I will like to know how the wall function is being implemented in the momentum equations for 2-D flow.
Thanks.
Ola
Old   June 27, 2002, 21:53
Default Re: Wall function application
Min-Hua Wang
Hello, All:
Is any body familar with wall function in rotational frame of reference. Say if the wall is moving, should I still keep the same wall function? Is there any transformation between moving wall and still wall?
Min-Hua Wang
Old   June 28, 2002, 01:29
Wen Long
I guess should use vorticity relative to the local rotation of the wall. Is the wall deforming?
Take Vr as the relative velocity of fluid relative to the wall, then Vr=Vf-Vw where Vf is absolute velicity of fluid, Vw is absolute velocity of the wall point then take Wr=Curl of Vr as the relative vorticity. Then try to use Wr in the wall function.
Hope it works, or maybe other gurus have better ideas
wen
Old   June 29, 2002, 15:29
Min-Hua Wang
Thanks. I am wondering what I can do in convert the wall function in a CFX-4 environment.
Min-Hua Wang
Old   June 29, 2002, 22:07
Wen Long
Hi, Min-Hua:
There is a very good review on vorticity conditions:
M Napolitano, G Pascazio, L Quartapelle, "A review of vorticity conditions in the numerical solution of \xi-\psi equations", Computers & Fluids, Vol28, 1999, pp 139-185.
Good luck,
wen
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 14:43
