Turbine Blade Data
Old   June 25, 2002, 02:43
Default Turbine Blade Data
Abhijeet
Hi all,
Can anyone tell me where to find the data of any (existing & in use) turbine blade ie , geometry (including the location & coordinates of cooling holes), temperature/wall heat flux distribution. I need to solve a practical problem to test my unstructured mesh code. If anybody work on this & has results ... we can compare our results.
Thanks
Abhijeet
Old   June 25, 2002, 06:28
Default Re: Turbine Blade Data
Nicola
http://www.unibw-muenchen.de/campus/LRT12/
There are very complete investigations about cooling effects on blade performance (high pressure blade AGTB and low pressure blade T106). Of course, experimental conditions are not turbine operating conditions (for the AGTB blade, total inlet temperature is 300K). You have to e-mail the contact person to have a user ID and a password.
Good luck,
Nicola
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 02:04
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 11:18
Flow study through Turbine Blade passage Subrata FLUENT 1 May 4, 2007 12:28
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
