Flux calculation
Old   June 25, 2002, 01:04
Default Flux calculation
Jika
Hello everybody,
While calculating velocities in finite volume method we use some schemes like upwind, QUICK etc. But to calculate flux across control volume face, simply the average value of the node velocities of the cvs to which the face belongs, are taken. Why a scheme a not adopted to calculate flux?
With regards
jika
Old   June 27, 2002, 08:24
Default Re: Flux calculation
Alex
It depends what kind of grid do you use. If you have staggered grid then you have the exact velocity value on the face. If you have collocated grid you have to interpolate the value between two CVs to which this face belongs. Staggered grids are only good for some primitive geometry with orthogonal lines. Collocated grids are much more flexible.
Old   June 27, 2002, 13:36
Jim Park
I think you mean "colocated," as in all variables for a control volume are located at the same place - Alternatively, forget the control volumes and say colocated variables are located at the nodes of the mesh.
"Collocation" is a mathematical term, and "collocated variables" are operated on in "collocation."
Old   June 28, 2002, 00:39
Jika
Thank you.
calculation of wall heat flux in CHT richard CFX 1 July 23, 2009 10:00
Flux calculation in vertex-centered finite volume. Martin Main CFD Forum 3 June 4, 2008 11:04
Error in flux at Fluent´s mixing plane calculation ales FLUENT 0 February 9, 2005 05:48
Warning 097- AB Siemens 6 November 15, 2004 05:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 09:19
