Outflow Boundary Conditions
Old   June 25, 2002, 00:37
Default Outflow Boundary Conditions
Jun Xia
Hi, everyone:
I do DNS of free jets, but I am not satisfied with the Outflow Boundary Conditions (OBCs) applied in my work, which always do not allow large vortex structures going through the outflow boundary fluently. Would anyone here please recommend a proper OBC to me? Many thanks for this.
Yours,
Jun Xia
Old   June 25, 2002, 04:41
Default Re: Outflow Boundary Conditions
Tom
For an incompressible flow a convective boundary condition should work: du_i/dt + U du_i/dx = 0. Make sure that the convective velocity U is always positive (and quite large if you still have problems at the outflow)
Tom
Old   June 25, 2002, 06:50
Jun Xia
Thanks, Tom. Sorry, I do not describe the question clearly. I simulated a compressible (subsonic) free jet and have tried several outflow boundary conditions, but the results are not so good.
Jun
Old   June 25, 2002, 07:21
Tom
Well, I guess that you know about the work of Freund & Lele or Pitsch (Stanford) in this field.
Tom
Old   June 25, 2002, 12:53
Patrick Godon
have you tried to impose non reflective boundary conditions, so that all the waves/perturbations can escape the computational domain without any trouble? This is done by imposing the boundary conditions on the charactersitics of the flow (in 1D these are the Rieman invariants). I know in numerical astrophysics many are simulating jets in the compressible regime and get trouble with reflection at the open boundary. The best way to treat that is to have non-reflective boundary conditions or transmitting boundary conditions.
See e.g. Givoli, 1991, Journal of Computational Physics, no.94, page 1 (review paper).
Patrick
Old   June 25, 2002, 15:08
Guus Jacobs
The numerical method you use in this respect is kind of important too. What are you using? Look at Grinstein JCP 94 for a good discussion on open outflow BC's for compressible turbulent flows.
Guus
Old   June 25, 2002, 15:46
Kalyan
In this context, it is also worthwhile pointing out that codes based on parabolized Navier Stokes solvers (like FCT, CCCT etc.) seem less problematic for simulation of near field jets. I say this based on observation since I have not worked PNS codes.
For other types of compressible solver, outflow BC is indeed a problem unless you extend the domain far downstream so that the flow at the outflow end of the domain is (relatively) convection dominated. The velocity perturbations due to small vortex structures are small compared to the average convective flow speed. In my experience with jet simulations, you need to extend the domain out (axially) atleast to 40 diameters so that the near field is unaffected by the outflow BC. COmputing unsteady flow in such a huge domain can be very expensive especially if one uses an explicit code like most LES codes but the expense seems to be necessary.
I do not think you can have a true non-reflecting BC in multi-dimensional CFD codes. Even the codes are based on characteristics, they are not genuinely multi-dimensional. There has been some interest a few years ago in developing genuinely multi-dimensional flux-split schemes but I do know how far they have come. Some one more informed can shed more light on this work.
Old   June 25, 2002, 23:18
Jun Xia
As to Freund' work, do you mean the following paper:
Title: Numerical simulation of a Mach 1.92 turbulent jet and its sound field Author: Freund, J.B.;Lele, S.K.;Moin, P. Source: AIAA Journal v 38 n 11 Nov 2000. p 2023-2031
Would you please recommend Pitsch's paper to me, which I do not know. Very thanks.
Old   June 25, 2002, 23:23
Jun Xia
Thanks. I use the 4-order compact finite difference scheme in space discretization, and 4-order explicit Runge-Kutta schemes in time advancement.
Old   June 25, 2002, 23:30
Jun Xia
Thanks. Would you please recommend an article on your former work about jet simulation to me?
With regard to the flux-split method, do you mean the PML (Perfectly Matched Layer) method, i.e. adding a daming item in the end of the equations, like
u_t = (original terms) - sigma*(u - u_damp) ?
Old   June 26, 2002, 04:55
  #11
versi
I think Convective BC is a reasonable one, though you need some experience in coupling the BC with the interior scheme to ensure numerical stability. The 4th-order compact scheme alone might encouter instability, especially mathed with a compex boundary conditions.
Old   June 26, 2002, 12:14
  #12
Kalyan
By flux split methods, I mean the methods based on right and left characteristics (Riemann solvers) at each cell face like the van Leer method. While methods based on van Leer scheme and Roe schemes work pretty well in 1-D (shock tube problems) they have problems when extended to multi-dimensional flows (carbuncle phenomena, artificial entropy decrease which is physically impossible). While each of these problems has been fixed (althoughly not all of them perfectly), the root cause remains the fact that you are extending 1-D characteristics based method to 2D/3D. Why is this extension such a problem when straight forward finite difference, finite element type method can be extended easily from 1-D to 2-D or 3-D. It is because these methods (van Leer, Roe schemes etc.) are inherently non-linear. The solutions are obtained from a Riemann problem using Godunov (type) methods instead of straight forward discretization and can be spatially/temporally discontinuous. Hence they do not fit in well with the multi-dimensional Taylor series expansions (need for extension to multi-dimensions and higher orders) which are based on a certain degree of smoothness in the solution.
Old   June 26, 2002, 14:55
  #13
Guus Jacobs
The last I have seen on finite difference is a compressible mixing layer simulation by Lui and Lele (AIAA-2001-0291). In this paper the Poinsot Lele BC is applied (JCP92) with temporal damping and an artificial convective term, i.e. one tries to get the flow towards a laminar state in a buffer region in which the solution is not worth much.
Old   July 9, 2009, 00:09
Nishant Kumar
Nishu is on a distinguished road
Hi Kalyan,
Do you have any code related to 1D Riemann problem?
Please send me at babuu.nishu@gmail.com
I need it for my research
Nishu is offline   Reply With Quote
Old   July 9, 2009, 06:56
Default "no" boundary condition
  #15
jed
Jed Brown
jed is on a distinguished road
Are you familiar with the "no boundary condition" outflow condition? Some relevant papers:
@article{papanastasiou1992nob,
  title={{A new outflow boundary condition}},
  author={Papanastasiou, T.C. and Malamataris, N. and Ellwood, K.R.J.},
  journal={International Journal for Numerical Methods in Fluids},
  volume={14},
  number={5},
  pages={587--608},
  year={1992},
  publisher={John Wiley \& Sons, Ltd}
@article{griffiths1997nbc,
  title={{The ``no boundary condition'' outflow boundary condition}},
  author={Griffiths, D.F.},
  volume={24},
  pages={393--411},
  year={1997}
@article{renardy1997inb,
  title={{Imposing ``no'' boundary condition at outflow: Why does it work?}},
  author={Renardy, M.},
  volume={24},
  number={4},
  pages={413--417},
  year={1997}
jed is offline   Reply With Quote
Old   July 9, 2009, 11:30
Ford Prefect's Avatar
Ford Prefect is on a distinguished road
Originally Posted by Nishu View Post
Hi Kalyan,
Amazing job digging up tons of out-of-date threads Nishu... I suggest you start a new thread instead with all your requests for different codes that you need in your research.
"Trying is the first step to failure." - Homer Simpson
Ford Prefect is offline   Reply With Quote
Old   July 9, 2009, 11:31
Nishant Kumar
hmmmm okay!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 07:25
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
