What's the advantage of Pseudo-compressiblity?
Old   June 12, 2002, 08:34
Default What's the advantage of Pseudo-compressiblity?
lololo
I am a beginner of this field. As we know, we can use Pseudo-compressibility idea for continuity equation in the incompressibility flow instead of a pressure-correction equation, then What's the advantage of Pseudo-compressiblity? Can you give me some words or show some papers? thank you in advance.
Old   June 12, 2002, 09:44
Default Re: What's the advantage of Pseudo-compressiblity?
Nicola
There are two classical approaches to solve incopressible flows: the one using pressure correction idea and the one using pseudo-compressibility idea. The choice between the first or the latter is essentially depends on personal taste, because both work well. Anyway, I think that pseudo-compressibility is used because it's easily implemented from previously existing codes for compressible flows. So, if you have a time marching code for compressible flows, the best choice, in my opinion, is the pseudo-compressibility approach. Look for "Chorin time marching" on the net to find some papers on the subject.
Pseudo time step Jun FLUENT 2 July 14, 2016 09:17
pseudo Time stepping vs real time stepping nileshjrane Main CFD Forum 0 October 19, 2010 06:13
need a pseudo code pritam.edke Main CFD Forum 0 November 13, 2009 08:36
[GAMBIT] grid topology advantage agungwp ANSYS Meshing & Geometry 3 August 28, 2009 10:44
local time stepping and pseudo time phil Fidelity CFD 0 February 27, 2006 17:26
