2D scheme for two-phase flow is needed
Old   June 11, 2002, 05:19
Default 2D scheme for two-phase flow is needed
Oleg
Hi all!
Is here anybody who can tell me of any publicly available CFD code that can deal with two phase flow and will be capable of tracking the fluid-gas surface? My problem is air-water flow basically laminar and basically in 2D...
I will highly appreciate any suggestions!
Thank you in advance...
Old   June 11, 2002, 14:26
Default Re: 2D scheme for two-phase flow is needed
rahmat, MEng
Oleg, I could suggest you to use fluent 5.2. There is two phase flow modul for your case. The approach for two phase flow is basically from VOM, cavitation model, slip mixture model. You can use one of them depend on your case. If you have any question, you can ask me.
Old   June 19, 2002, 07:51
Oleg
Rahmat, thank you very much, but I am new to CFD and especially to the commercial CFD packages. So, my next question is as follows:
Can I get this package (i. e. Fluent 5.2) fom somewhere for evaluation, or even if there exist any good freely available version, etc?... can you please tell me?
Old   June 19, 2002, 11:31
cfd
hi
i don't know much about free or commercial CFD packages for 2-phase flow models. can i suggest you to develop you own code all you need some-time to understand the mathematical structure then the numerical methods you need. i.e. what i've done i never used any package.
good luck. cfd
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Two phase flow with condensation Sunnie FLUENT 0 May 31, 2009 11:02
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 03:32
