IMPINGING JET PROBLEM
Old   January 21, 1999, 14:46
Default IMPINGING JET PROBLEM
Chuck Leakeas
I have some questions about a circular impinging jet problem that I am working on. Here it is:
I have a axisymmetric jet in which the Reynolds number inside the jet is 93, and the velocity profile given is for a laminar flow. When the flow leaves the nozzle and expands normally into a wall some distance away will the entire flow field still be laminar, or is there a chance that there may be some turbulence generated? If so, how would I know that there is turbulence?
Any comments or suggestions would be greatly appreciated. Thanks in advance.
Chuck
Old   January 22, 1999, 09:21
Default Re: IMPINGING JET PROBLEM
Achuth Rao
Is your jet impinging on to a wall or expanding in free space. Are you interested in cfd or experiments.
If the jet is impinging against a wall then depending on the distance between the nozzle and the wall it could develope disturbances which could make it turbulent.
Old   January 22, 1999, 12:56
Chuck Leakeas
Thanks for the response Achuth, actually I am numerically modeling this problem. The Reynolds number inside the jet is 93 with a fully developed and laminar velocity profile. The centerline velocity is 100 m/s while the impinging surface is located 4 nozzle diameters away from the nozzle exit. Is there anyway to say for sure if there is turbulence generated near the impinging surface? Any comments would be greatly appreciated.
Old   January 23, 1999, 01:19
Chuck Leakeas
Sorry, my mistake, the centerline velocity is 1.0 m/s.
Old   January 29, 1999, 18:43
John C. Chien
The formation of the shear layer is relatively unstable because of the profile shape and the growth of the shear layer. So, you may want to look into this area more closely.
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 21:18
How to design an impinging turbulent jet Pierre Siemens 1 January 9, 2009 12:48
Impinging Jet in ICEM - Negative volume Stuttgart CFX 1 September 19, 2008 10:11
impinging jet natesan Siemens 1 February 25, 2005 04:16
Impinging Jet Modeling Problem Anindya FLUENT 1 August 11, 2001 04:16
