Axisymmetric Inviscid Compressible Euler code.
Old   May 27, 2002, 13:57
Default Axisymmetric Inviscid Compressible Euler code.
Amith
I need an Euler code for axisymmetric, inviscid compressible flow. Does anyone have it?
Thanks in advance, Amith.
Old   June 10, 2002, 17:29
Default Re: Axisymmetric Inviscid Compressible Euler code.
Clifford Bradford
search for NSC2KE at google or any other search engine or go to http://capella.colorado.edu/~laney/softaero.htm and follow the links to it.
Old   June 11, 2002, 00:32
Amith
Thanks for your help! Do you know where I can find the implementation details for axisymmetric cases by finite volume methods and not finite difference methods.
With Regards, Amith.
Compressible code problems praveen OpenFOAM Programming & Development 0 April 11, 2011 01:00
N-S code for flat plate compressible flow varunjain89 Main CFD Forum 2 March 24, 2010 12:43
2D Euler code for optimization odyssey Main CFD Forum 1 March 11, 2010 00:04
Inviscid Euler flow Ryan Sidin CFX 1 May 18, 2007 23:36
CFD code about axisymmetric bodies at hypersonic speeds Afshin Azari Main CFD Forum 5 October 26, 1998 18:09
