May 16, 2002, 18:55 |
Book recommendation?
Hello
Can someone recommend a good book that covers heat and mass transfer (with kinetics) in porous media? Thanks Jason |
June 5, 2002, 23:45 |
Re: Book recommendation?
Sir i am working on research project "revemping of Francis Turbine applying CFD". I have got book "An introduction to computational fluid dynamics (finite volume) by malalasakra" it is very good book and i have understand SIMPLE, SIMPLER AND SIMPLEC method of solving Navier Stock equation but in this book just presentation that how Navier Stock equation can be solved but there is no solve example. Do you know any book or article in which this type of example is present. I mean that for any given problem(good if turbine rotor)firstly assume pressure field and then find velocity field then check pressure correction equation and repeat this procedure still convergence occure. waiting for your prompt reply thanks
Spectral Methods in Fluid Dynamics | Martin Bailon | Main CFD Forum | 3 | January 31, 2011 13:39 |
book recommendation: hydrodynamics | thomas | Main CFD Forum | 0 | February 15, 2008 01:28 |
Book recommendation need for all speed flows | jinwon park | Main CFD Forum | 0 | February 6, 2008 11:34 |
free on line compressible flow book | genick bar-meir | Main CFD Forum | 4 | December 5, 2005 00:25 |
free on line compressible flow book | genick bar-meir | Main CFD Forum | 0 | November 9, 2005 20:56 |
