SOR Fails Near Walls
Old   May 9, 2002, 02:05
Default SOR Fails Near Walls
Chih-Wei Chiu
I simluate unsteady free-surface flow on a stagger grid (MAC).
I found the SOR (successive over-relaxation) code fails often in the cells next to obstacle cells (wall). This happens when I simulate a high speed flow hitting on the wall. The divergence of the cell is very large, because a lot of fluid rush into this cells at the same timestep, and there are be two or more onstacle faces (whihc fluid can now flow through) in this cell.
How can I solve this problem?
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
Heat loss through walls franzdrs FLUENT 6 March 29, 2010 13:11
2 Domains share their walls...any interface ? KK CFX 2 February 7, 2008 17:34
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 07:17
