advice needed!
Old   April 26, 2002, 08:57
Default advice needed!
Filip
Hi there,
i would greatly appreciate it if someone could give me some advice on the following subject. i really could use some different viewpoints on how-to approach this problem.
i am an aerospace student and i am only familiar with the basics of aerodynamic design and cfd. i really would like to get started on a front wing design of a formula-type race-car. it is a existing double wing design (wing + flap) of which only the flap is free to be modified due to regulations.
at this point i don't have access to a windtunnel, but i would like to start with a 2D optimization of the flap surface in CFD. I am familiar with -again sigh - the basics of programming in C++ but i know more about Matlab. So my question is, is there any existing code which would be a good starting point ? I could imagine that not every code would be able to generate results which do for ex. account for the reattachment of the boundary layer on the flap surface, or the detrimental effect of the wing on the flap surface pressure distribution. Then there's the ground effect...In short, i do not really know where to start with all this software and programming languages. I reckon this question is very general, but pieces of advice would be great ...
Thanx in advance,
Filip
Old   April 26, 2002, 16:23
Default Re: advice needed!
Axel Rohde
Filip,
Download and install my shareware MicroTunnel,
www.microcfd.com
It can handle 2-D multi-element flow (wing + flap) and you can also switch on ground effect. It is based on an inviscid solver, but you can 'model' boundary layer effects buy turning on a surface roughness parameter.
For a race car, use a Mach number of M = 0.2 (150mph).
Good luck!
Axel Rohde
Old   April 26, 2002, 16:27
Axel Rohde
... buy turning on ...
No subliminal message intended here!
Should read: ... by turning on ...
(Having a bad spelling day!)
Axel
Basic advice on Importing Solid Edge model to CFX needed. stephen__white CFX 1 February 9, 2011 19:40
[snappyHexMesh] Advice needed lindsaywestraadt OpenFOAM Meshing & Mesh Conversion 2 February 18, 2010 03:20
Prism layer advice needed for port flow case MaxCFM ANSYS Meshing & Geometry 0 October 2, 2009 09:42
Prism layer advice needed for steady state port flow case MaxCFM Main CFD Forum 1 October 1, 2009 10:26
SUPG for 2-D Navier-Stokes advice needed.. nicole Main CFD Forum 2 November 23, 2002 01:06
