MUSCL limiters????
Old   April 25, 2002, 03:58
Default MUSCL limiters????
Michel
I wrote an Euler code it uses Van leer /Steger warming as well as Roe scheme...I added the MUSCL type limiter....Im having slow convergence somehow and after certain numerical experimentations I discovered that the MUSCL has something wrong...Im wondering wether I should set the limiters to zero at the boundaries to resolve this problem....any suggestions???
Old   April 25, 2002, 06:55
Default Re: MUSCL limiters????
cfd
hi
have a look to chap. 13 & 14 in Toro's book. the best to use is SUPEREBEE limiter. anyway, the book is
Riemann solvers and numerical methods for fluid dynamics
E. F. Toro; Springer
Old   April 28, 2002, 05:47
versi
Two references may help you about MUSCL:
1. W. Anderson et al, AIAA P 85-0122, 1985.
2. L. Yuan, JCP Vol. 177, p.138, 2002.
Old   April 29, 2002, 11:07
Anvar Gilmanov
See also an article:
A. Gilmanov. A Local Characteristic Approach in High-Order Differencing // J. Computational Mathematics and Mathematical Physics (Russian Journal). 2000. Vol. 40. No. 4. P.529-533 (in English).
A limiter I use is very good.
Anvar
Trouble when using MUSCL scheme on ONERA M6 wing Aurélien FLUENT 2 January 23, 2013 08:42
Help: Third-order MUSCL for flame propagation? fireman FLUENT 3 October 13, 2010 13:33
MUSCL scheme implementation ANPDEstudent Main CFD Forum 1 June 27, 2010 00:57
ROE Riemann Solver and MUSCL ares Main CFD Forum 10 May 7, 2010 05:47
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 12:21
