Channel LES and explicit filtering
Old   January 17, 1999, 11:07
Default Channel LES and explicit filtering
Luca Liberti
I am trying some calculation with LES dynamic model in a 3D channel. Many authors use top hat filtering function to perform the explicit filtering operations. The convolution integral is evaluated by means of linear interpolation of the function to be filtered and dicrete integration rule (Zhang). In a laminar flow the right hand term in Germano's identity (i.e. the difference between the corresponding components of the coarse grid stress tensor and the filtered fine grid ones) should be zero as states Ghosal. But in a laminar channel flow the wall to wall velocity profile is parabolic and in my calculation the trace of this term shows a maximum on the first point near the wall. Is the problem due to a too coarse grid resolution (32x16x32 and same geometry of Kim and Moin DNS) or to the filtering operation? Thank in advance for any help.
Explicit filtering in LES TJ Main CFD Forum 85 November 30, 2016 06:22
LES explicit filtering maka OpenFOAM Running, Solving & CFD 4 December 27, 2012 10:08
LES explicit filtering Paul Main CFD Forum 0 March 17, 2006 09:03
LES (explicit) filtering John Main CFD Forum 2 July 29, 2004 19:03
