April 24, 2002, 06:43 |
CV flux correction in SIMPLE
HI All, In my code I need to construct a residual analytical function (Navier-Stokes) using FVM. The solution of any code based on SIMPLE algorithm on a colocated grid I introduce in my code does not satisfy the mass conservation, since I don't know how to correct the velocity on the face explicitely from a given (U,V,P) on the cell center. I tried the Rhie and Chow interpolation but it seems implicit.
In the staggered arrangement case, I don't have this pb since the velocities given are on the cell face. Any idea? Thanks a lot |
April 24, 2002, 16:55 |
Re: CV flux correction in SIMPLE
You could try to implement the staggered arrangement. It is harder to implement since you need different locations for each velocity and pressure but it makes life easier since you don't need to use interpolation and get the velocities in the CV face. In Patankar's book you can find an explanation on how to correct the velocities and specify boundary conditions for the pressure equation on staggered grids.
April 25, 2002, 04:21 |
Thank you Peter for your suggestion. The staggered case works very well for the reason you explained. Actually I need to work with colocated arrangement, since they are easier to implement for non orthogonal grids or 3D cases. For this reason I need an explict way to recompute the velocities on the faces from the field on the cell center so that the mass conservation is satisfied.
thanks again |
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 17:25 |
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 03:23 |
PISO vs. SIMPLE | benedikt flurl | Main CFD Forum | 2 | April 14, 2005 07:54 |
Pressure correction on SIMPLE | Diego Nogueira | Main CFD Forum | 6 | October 10, 2004 15:43 |
Block correction scheme in SIMPLE | Chuck Leakeas | Main CFD Forum | 0 | November 20, 1998 13:51 |
