Simulating a Supersonic Diffuser-Need Help
Old   April 17, 2002, 05:53
Default Simulating a Supersonic Diffuser-Need Help
Dileep
Hi friends, I face problems in simulating a supersonic diffuser flow. I use a UNS FVM solver. The inlet mach no. is 3.5 and no condition is specified in the down stream side(pressure extrapolated). The diffuser is supposed to be of proper dimensions with a straight long throat. Still the flow has not become subsonic or no shock is formed. The exit pressure is above the expected value. My doubts are:i) Should I specify the subsonic conditions at the down stream side? ii) How can I implement that? iii) If I specify the exit pressure will it simulate the real situation? Could any one give some help?? Thanks.. Dileep.
Old   April 18, 2002, 07:25
Default Re: Simulating a Supersonic Diffuser-Need Help
Jitendra
Hi Dileep,
You can implement a boundary condition which can check every iteration whether the live cell Mach no at the exit is subsonic and supersonic. It should apply pressure for subsonic case else go for extrapolation.
Note : Not the expert's comments ... any other suggestions... please enlighten me also.
Regards,
Jitendra
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 19:01
Flow in Supersonic MHD Channel Antanas CFX 6 February 13, 2012 15:49
Supersonic Combustion Andrew FLUENT 1 March 16, 2011 07:00
turbulence model for separated flow in diffuser Martis STAR-CCM+ 0 March 2, 2010 03:08
CFD code for supersonic flows hedy Main CFD Forum 9 April 16, 2007 11:56
