Flux vector splitting of Inflow/outflow BC
Old   March 24, 2002, 22:30
Default Flux vector splitting of Inflow/outflow BC
Quain Tchew
Hi
I'm reading a code. In the code, inflow/outflow bc is handled with Flux vector splitting:
normal flux on the boundary face of the cell = integrate_on_the_face ( ((A+)*(Win)+(A-)*(Wex))*n )
A+ is the positive Jacobian Matrix A- is the negative Jacobian Matrix Win is the primal var on the inner side of the face Wex is the primal var on the outer side of the face
What does that mean? Where can I fined a detail introduction about Flux vector splitting of Inflow/outflow BC on web?
Old   March 25, 2002, 10:43
Default Re: Flux vector splitting of Inflow/outflow BC
gita
You can refer to this book: C. Hirsch, Numerical Computation of Internal and External Flows, Vol. 1 and 2, 1988 Wiley.
There are different types of flux vector splitting schemes like van Leer(based on Mach No),Stegar-Warming(eigenvalue based),hybrid FVS(flux vector splitting) like AUSM(Advection Upstream Splitting Method-pressure based splitting).
If you're new to these schemes(flux-difference and flux-vector),then I suggest you should read Hirsh so that you gain some insight into those numerical methods. Basically these compressible schemes split the fluxes into positive and negative fluxes(inviscid) across each cell of the volume so that the correct flow information is incorporated(direction of the propagation of wave speeds). When you deal with compressible NS flows,you apply these flux-difference/flux-vector/hybrid splitting schemes only for the inviscid part. Do you want to know the physical meaning behind these different splittings? I can explain... Regards
Old   March 25, 2002, 10:54
Quain Tchew
Hi! gita, Thank you.
I have read some books about that. But I still don't know how to apply flux vector splitting in inflow and out flow boundary.
I met this problem when I was reading the NSC2KE code(http://pauillac.inria.fr/cdrom/prog/unix/nsc2ke/eng.htm). In the page 10 of the guide of NSC2KE, there is a paragraph about "Inflow and outflow weak boundary". But I can not understand.
Regards Quain Tchew
Old   March 25, 2002, 12:25
Praveen Chandrashekar
Refer to the paper by Steger and Warming as suggested in the manual.
Old   March 25, 2002, 20:43
Quain Tchew
oh, I can't find it.
But I think I have catched on it.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 10:50
flux around one specific cell solefire FLUENT 0 October 7, 2010 18:25
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
