use of common RANS B.C.'s in LES?
Old   March 21, 2002, 07:08
Default use of common RANS B.C.'s in LES?
Sanjin Saric
I'm working on the RANS non-commercial code (standard k-eps turbulence model, SIMPLE algorithm, collocated grid, a second order space discretization method, the time integration is of second order using a fully implicit method with three time levels). The case to be simulated (modifying the existing code to perform LES with Smagorinsky model) is a low Re turbulent flow over backward-facing step. However, the proper B.C's for LES, periodic (in a spanwise direction) and convectiove outflow (outlet), are not available in the code. I wonder if anyone has an expirience in using the existing (although not physically correct?) symmetry (spanwise, 4h) and zero gradient (outlet, at x=35h) B.C.'s instead (typical for RANS) in LES simulation? Any suggestion or comment will be appreciated
thanx a lot in advance
Sanjin
RANS to LES: Flame dissapears?? LB Main CFD Forum 4 September 6, 2007 19:53
Laminar Flamlet RANS to LES LB FLUENT 0 September 5, 2007 06:35
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 06:31
someone to answer..Difference between LES and RANS Nik Main CFD Forum 2 September 4, 2005 12:40
RANS results for LES Li Yang Main CFD Forum 5 June 17, 2002 06:34
