turbulence wall law on unstructred mesh
Old   March 13, 2002, 03:01
Default turbulence wall law on unstructred mesh
Quain Tchew
I'm developing a code computing 3D compressible turbulence flow on unstructured mesh.
I don't want to make many hexahedrons near the wall, for this method requires enormous computing. I want to implement wall law on tetrahedron mesh.
I know I must calculate y+ and u+ of the near wall Control Volume(CV), and then according the y+, use different function calculate turbulence viscidity.
But which CV should I calculate? Some CV have a face on the wall, some have a edge on the wall, and some have a vertex on the wall.
How to calculate the turbulence stress resulted from the wall, k and e in the near wall CV? Should I integrate in a tetrahedron?
Old   March 14, 2002, 06:29
Default Re: turbulence wall law on unstructred mesh
Bart Prast
That's why most codes use prisms at the wall.
Old   March 18, 2002, 21:03
Quain Tchew
I see.
But how can I generate prisms at the wall? can Gambit or gridgen do it?
If I have to progame to implement it, where can I find some article about it?
Thanks
Old   March 19, 2002, 17:14
Astrid
Gambit can do it, definitely.
Astrid
Old   March 20, 2002, 10:50
Default Re: prism grid generation
Pete
Gridgen can generate layers of prism cells as well.
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
