stability analysis on FVM
Old   March 11, 2002, 06:50
Default stability analysis on FVM
robert
I am working on stability analysis on upwind scheme approximation of N-S equation based on staggered grid. Any one know how to deal with such problem?
Thanks for your information
Robert
Old   March 11, 2002, 09:51
Default Re: stability analysis on FVM
gita
Hi robert,
What do you mean by "such" problem? You want to know the performance of upwind schemes? How familiar are you with upwind schemes?(first order,TVD,MUSCL-Monotone Upstream-Centered Conservation Laws scheme). Are you dealing with incompressible or compressible flows? First order schemes are highly consistent and stable. Normally you can make your code run safely with first order(for any case) but it has its own disadvantages. So you go for second order and in that case you have to use limiters. Be specific about your question so that you get straight answer Regards gita
Old   March 11, 2002, 11:38
robert
Hi, gita,
Thanks for your concern and suggestion for further discussion. I am using first order upwind scheme for imcompressible flow such as water. I encountered one problem if the viscosity is very low or very high (different application), the flow became unresonable or the results was not symetric during symetric problem. That is why I want to do stability analysis. May I know what is your advice?
Thanks
Best Rgds
Robert
Old   March 11, 2002, 12:03
robert
Hi gita,
I am using SMAC method to solve the N-S equations, so the momentum equation is used to get the first try value for velocities (explicit), then solve the poisson equation for potential function to adjust the tilde velocities to final ones.
I hope this is clear.
robert
Old   March 11, 2002, 23:55
Paul
Hi, Robert, here is just a trivial point. You mentioned that your results for high Reynolds may be unsymmetric for some symetric problem. This may be reasonable, due to the so-called `elliptic instability', and has been verified with two-side driven cavity (JFM, v336, 1997 or T.C.F.D, v14, 2001). Anyway, the low-order upwinding scheme is quite stable.
Old   March 12, 2002, 10:35
gita
Hi Robert,
As Paul said your results could be reasonable and you need to refer to some journal articles along these lines. As far first order upwind is concerned,there is no stringent restriction on the cell Peclet no and you can use large delta x. You have to look into the truncation error expression. In the TE of FDA, you will have artificial diffusion term sitting. If that doesn't represent the actual physical diffusion,then you will have problem. You can do von Neumann stability analysis to find the bounds for your convective-diffusion terms. Assume that it's 1D problem,then in the TE expression you will have term udeltax/2(u is your convective vel).This is the additional term sitting and acts as artificial diffusion. If this is much smaller than your actual viscosity(nu),then it's fine. When they are of same order,then you have to be careful. It may introduce unwanted wiggles in your solution. Try second order upwind and see whther you face the same problem. If you want learn more about limiters(which you need for seonc order upwinds)there is a nice SIAM journal paper by Sweby. I can get you the details if you're interested(I don't remember the year off handedly) cheers
Old   March 12, 2002, 11:15
robert
Hi, gita
Thanks for your important information. I expect your detailed information about the journal paper by Sweby. As you said, there is artificial diffusion |u|dx, normally, the viscosity nu is less than the artificial diffusion in my study. the results is totally wrong or not? I am checking with the papers paul suggested.
Best wishes
robert
Old   March 13, 2002, 09:49
gita
Hi Robert,
The paper on limiters is Sweby,P.K "High Resolution schemes using flux limiters for Hyperbolic conservation laws", SIAM J Num Anal. vol. 21 (1984). Regards gita
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
Stability Analysis skg Main CFD Forum 3 June 15, 2006 09:41
numerical stability analysis Wen Long Main CFD Forum 1 May 22, 2002 01:14
FD and Linear Stability Analysis Zeng Main CFD Forum 1 March 28, 2001 04:48
Stability analysis on a non-uniform grid PRAVEEN CHANDRASHEKAR Main CFD Forum 7 July 2, 1999 02:46
