QUESTION for all the Brains in the house
Old   January 12, 1999, 22:42
Default QUESTION for all the Brains in the house
steven Min
If a tank containing 15000 gallons of water were to be suspended up 40' and has a pipe coming out straight down 30' measuring 10" in diameter then reduce to 1" travelling for a distance of 20' parallel, what is the PSI at the output? what is the fomula for calculating such answer?
Iquiring mind wants to know
Steve
Old   January 20, 1999, 08:18
Default Re: QUESTION for all the Brains in the house
Jeff Franklin
I believe this problem cann't be solved unless the geometry of the tank is given. When it is then it becomes a fluid head problem where the pressure depends on the difference in height of the surface of the water in the tank and the exit of the pipe coming out. Check any basic fluid text to solve this problem.
Good luck,.
Jeff
Unanswered question niklas OpenFOAM 2 July 31, 2013 17:03
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 16:26
Question about Table applicaiton. universez OpenFOAM Running, Solving & CFD 0 January 12, 2010 21:31
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 06:55
question K.L.Huang Siemens 1 March 29, 2000 05:57
