Low Reynolds Number Flow Computation
Old   January 22, 2002, 04:42
Default Low Reynolds Number Flow Computation
A.M.Yang
What are the difficulties in the computation of low Reynolds number viscous flow?
Thank you in advance.
Old   January 22, 2002, 05:13
Default Re: Low Reynolds Number Flow Computation
Andrey
Low Reynolds number viscous flow - no problem! It's very simple!
Old   January 22, 2002, 05:42
Alexey
It depends on Mach number. If M is not small (for example > 1) this problem is not "very simple!"
Alexey
Old   January 22, 2002, 07:35
Andrey
If Mach number too big -> Reynolds number not small!
Old   January 22, 2002, 09:55
Farshid
If the scale of your simulation is of the order of hundreds of micro meters or less, you might have some problems with boundary conditions. For instance, no slip b.c.'s may not be valid. Especially, this problem arises when Mach number is large.
Old   January 22, 2002, 10:28
Christian Holm
Does that not depent on weather the assumption of the fluid being a continuum holds ? ie. if we have a thin low pressure gas and small dimensions, then the eq. we normally use are not valid.
Christian
Old   January 22, 2002, 12:16
mukkarum hussain
plz send me books on this topic and on cfd thanks
mukkarum
new one in cfd
Old   January 22, 2002, 13:01
Alexey
Situation when Re is small and M is big may take place when gas is strongly rarefied. In this case either Navier-Stokes or Boltzmann equations are used depending on Knudsen number.
=Alexey
Low Reynolds Number Flow over a Flat Plate Go FLUENT 4 August 28, 2013 06:19
low Reynolds Model for pipe flow RugbyGandalf OpenFOAM 9 July 4, 2011 12:28
Flapping Airfoil Simulation in Low Reynolds Number Flow M.Sc_Student FLUENT 4 April 7, 2010 11:28
Combination of high and low Reynolds number adolfo FLUENT 0 June 24, 2005 14:09
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 14:46
