Solid Boundary Condition
Old   January 11, 2002, 05:05
Default Solid Boundary Condition
zhanglei
I am working on a computation in which solid boundary condition should be used. Because several layers of ghost points will be added artificially on the boundary, I wonder how to determine their values according to the known values of the flow field. p.s. My problem is about compressible inviscid flow.
Any comment is welcome!
Yours Sincerely Zhang Lei
Old   January 11, 2002, 07:31
Default Re: Solid Boundary Condition
John
I don't know what method you used. In general, you have discretised equation look like:
A_cell * PH_cell = sum (A_neighbour * PH_neighbour) + source
For solid cells: just set A_cell=1.e+25 (a big number) and source=0.
so that the solver will give PH_cell=0.
You have to treat the boundary between these ghost cell and real fluid cell as proper wall.
Old   January 11, 2002, 08:27
Paul
Hi, Seems that you are dealing with compressible Euler system or something similar. If that's the case, solid boundary should be reflective boundary. Hence, you just inverse the velocity perpendicular to the boundary and keep all the other values.
Old   January 11, 2002, 14:03
sprasaath
respectful li,
hello i am prasaath from india. i am a mechanical engineering student. do u have anything to say to me as i know very little about CFD . mail me back.
yours sincerely
s.prasaath
Old   January 12, 2002, 18:27
Johnix
Ask Jamson ...
Hu ...
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
How To Convert Fluid wall in Solid Wall Boundary Condition RGN FLUENT 4 March 31, 2009 05:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
