Stirling engine simulation advice needed
Old   December 13, 2001, 10:07
Default Stirling engine simulation advice needed
Geoffrey
Hello
I am simulating a Stirling Engine on the basis of simple one-dimensional compressible internal flow. I am using the following conditions:
it's one-dimensional flow, so no boundary layers. I am using classical heat transfer and friction equations only 5 elements using runge-kutta to step forward in time. the elements are linked via equilibrium equations at each interface. Inside each element I am using conservation of mass, internal, thermal and kinetic energy
I think this is an implicit method
AND, this has been derived from a simple program developed about 20 years ago. I do not have a CFD book and really need to know what would be a good book to fill me in. Or, even better, contact with someone working in a similar field.
OK, thanks and hope to hear something if anyone is not too busy with other stuff.
Old   December 17, 2001, 05:02
Default Re: Stirling engine simulation advice needed
Christian Holm
Hi.
I am not quite clear on your problem, but here goes: If you only want to calculate the heater/cooler/regenerator size or the output power, I don't think you need to go into CFD. The problem you describe can be solved with knowledge of thermodynamics and basic friction equations and of cause some math.
I guess that you already know the book: "Stirling Engine Analysis" by Urieli and Berchowitz. It is a classic. It takes you from the basic to an acceptable analysis of the Stirling engine. A new book that might be a classic some day is "The Regenerator and the Stirling Engine" by Organ.
If you want to do more detailed calculations, the thermodynamic issue in the engine offers plenty of challenge. If you want to do CFD calculations and need some good books: Basic Fluid dynamic book: "Introduction to fluid mechanics" by Fox and McDonald. CFD book: "Computational Methods for Fluid Mechanics" by Ferziger et al.
You can find a lot of suggestions on http://www.cfd-online.com/Books/
What are the issues you want to study. Is it to reveal the flow in the heat exchanger components or the cylinders or to evaluate the parasitic losses ?
Hope this helps.
Christian
Old   December 18, 2001, 03:26
P.Fonteijn
These guys might help you:
www.stirling.nl
Cheers, Pascale
Modeling Stirling Engine kilovolts OpenFOAM Running, Solving & CFD 2 February 3, 2021 00:50
Needed Help on Welding Simulation Process darshankapadia FLUENT 0 August 7, 2010 09:37
3D engine simulation experiment yubaibai88 FLUENT 0 April 20, 2010 09:59
4 stroke engine inlet/exhaust simulation flo777 CFX 3 March 16, 2010 17:44
advice needed! Filip Main CFD Forum 2 April 26, 2002 16:27
