Should I use preconditioning ?
Old   December 10, 2001, 16:47
Default Should I use preconditioning ?
Vajra
Hello all,
Can anyone tell me if I can use a compressible flow solver using Roe scheme to simulate a low speed flow of Mach number around 0.01 or lower without preconditioning ?
Regards
Vajra
Old   December 12, 2001, 06:23
Default Re: Should I use preconditioning ?
Alexey
Yes. The fact that the compressible flow does not depend on Mach number if Mach is close to zero. I think you will get the nearly same solutions for M=0.2...0.1 (in dimensionless form)
Alexey
Old   December 12, 2001, 06:39
Vajra
Thanks Alexey,
Could you tell me where I could find out some papers dealing with such kind of preconditioning ?
Vajra
Old   December 12, 2001, 13:03
chidu
That would be impractical. The system becomes stiff when the Mach number tends to zero. Preconditioning is probably the best way to overcome the stiffness. A simple form of preconditioning could be Chorin's artificial compressibility method which would not require extensive changes to the code. The reference is:
Chorin, A. J., A numerical method for solving incompressible viscous flow problems, J. Computational Physics, vol 2, pp. 12-26, 1967.
If your problem has important boundary layer effects then you might need more complicated preconditioning approaches, check the work of Merkle C. L.
cheers, chidu...
Roe implement about preconditioning ricklee Main CFD Forum 7 July 7, 2006 07:14
Re: Preconditioning for moving grids ganesh Main CFD Forum 0 April 6, 2006 07:18
Preconditioning in 3D ganesh Main CFD Forum 0 February 28, 2006 07:39
implementing preconditioning clifford bradford Main CFD Forum 0 October 19, 2000 17:03
local preconditioning Manish Jaiman Main CFD Forum 3 May 1, 2000 09:31
